Fitting top wood on 29 CCPU
This is maybe a stupid question but do You normally have to do alot of custom fitting on the top wood on a 29 CCPU? My side wood above the door going from the rear cab corners are sitting down tight on the rear cab corners but the rear cab top wood doesnt fit down tight on the upper portion of the rear cab panel. I have the cab fitting good on the frame. The doors fit pretty good and the cab is square. It seems I need to trim the side wood on the rear corners so the back cross wood will fit down tighter. I have a 1/2" gap between the top of the back panel to the cross wood. Any Ideas?
