Old 11-25-2021, 12:53 AM   #1
Blindhuckster
Blindhuckster's Avatar
Default Changing Standard Steering Wheel to a Banjo on a 1936
I have a buddy that has a 1936 Coupe that has a standard steering wheel. He would like to change it to a 36 Banjo wheel if he can locate a good original. Can the original standard steering wheel horn- light switch rod assembly be retained and used with the banjo wheel? Or is there a difference in those, that would require that to be changed as well? Thanks Nate Anello
Blindhuckster is offline   Reply With Quote
Old 11-25-2021, 01:38 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Changing Standard Steering Wheel to a Banjo on a 1936
So you don't damage the Steering Wheel while trying to remove it, you need a Steering Wheel Puller like this one.
Old 11-25-2021, 03:20 AM   #3
Brian
Brian's Avatar
direct change over; the horn button/light switch affair remains the same
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 11-25-2021, 08:36 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
If you have the correct '36 banjo steering wheel, it's directly interchangeable.
Notice the "strings" on the '36 banjo wheel are sorta flat, not angled or splayed like the '37-'39 banjo wheels, and the "strings" are separated by 3 barrelled/bar stock shaped parts.
John
Old 11-25-2021, 12:08 PM   #5
VeryTangled
VeryTangled's Avatar
Originally Posted by Blindhuckster View Post
I have a buddy that has a 1936 Coupe ... Can the original standard steering wheel horn- light switch rod assembly be retained and used with the banjo wheel? ... Thanks Nate Anello
Hi Everyone You didn't ask Nate, but unless he's already familiar you might have your buddy learn-up on the importance of being gentle with that rod.
Another thing to be aware of for this job. If it comes time to lower the column drop/lock/switch, there was a break-off bolt installed at manufacture. If it's never been out they'll have another challenge. Search break-off bolt here for more details and pics.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 11-25-2021, 03:12 PM   #6
Steve in Denver
Steve in Denver's Avatar
The complete steering column mechanism is also held to the dash by two bolts that can be removed by reaching up under the steering column. Easier than drilling out the break-off bolts.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 11-25-2021, 05:08 PM   #7
mercman from oz
This is what the finished product would look like - Closed 1936 Ford Deluxe with Accessory Banjo Steering Wheel.
Old 11-25-2021, 09:42 PM   #8
Blindhuckster
Thank you, for all the good advice, I was aware of the care that needs to be taken with the rod and will pass all this along to my buddy. Car was frame off restored in the 80"s and kept in a climate controlled storage, so would assume the disassemble will not be an issue. I will pass all this good information along to him. Again, thanks for all the help.
Old 11-26-2021, 03:48 PM   #9
36coupe
36coupe's Avatar
I used a bearing separator/splitter under the wheel to spread the load then a 3 legged puller. Worked good no issues.
36coupe is offline   Reply With Quote
