Old 11-08-2021, 12:32 PM   #1
Ratchet
Default New to The 1926 Ford Model T
Hi,
Just wondering what is the best place to get parts for the Model T, currently looking for rear axle bearings at the wheel end.
Thanks
James
Ratchet is offline   Reply With Quote
Old 11-08-2021, 07:17 PM   #2
Utopia Texas
Utopia Texas's Avatar
Default Re: New to The 1926 Ford Model T
I usually deal with Snyder’s or Lang’s for parts. Snyder’s sells both Model A and Model T parts. Lang’s only sells Model T parts but also has a huge inventory of good used parts
Utopia Texas is offline   Reply With Quote
Old 11-08-2021, 07:48 PM   #3
Ratchet
Thank You!
I will certainly check them out.
James
Old 11-11-2021, 10:08 PM   #4
39portlander
39portlander's Avatar
Chaffins garage as well, also check the "for sale" on the MTFCA web site those are always up for grabs.
39portlander is offline   Reply With Quote
Old 11-12-2021, 06:21 PM   #5
SteveBoothroyd
Am I not remembering correctly, but did Chaffins have some rear axels made and heat treated, including some that could be ordered slightly longer?
I ordered a pair and they have been great with no problems.
I was able to obtain some original roller bearings that were well within specs and at the same time, rebuilt the entire rear end with new parts and it took a while to get the tolerances correct by thinning ever so slightly the bronze thrust washers.
Steel safety wired as well.
Regards,
Steve Boothroyd
SteveBoothroyd is offline   Reply With Quote
Old 11-12-2021, 06:23 PM   #6
SteveBoothroyd
Ring and pinion gears were also fitted to within tolerances, according to the MTFCA book on re-building the T rear end.
Regards,
Steve Boothroyd
Old 11-16-2021, 04:47 PM   #7
Ratchet
Another parts vender that's awesome thanks guys.
James
