Old 11-06-2021, 04:39 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Turn Signal Flasher 12V
This post is a point of information.
After a lot of iterations to discover why the turn signal indicator lamp was rarely working, I narrowed the problem down to the thermal type flasher. I replaced it with a Novita EL13 12v 3-prong unit and the indicator lights work consistently with an audible clinking noise. The EL13 Flasher is semi-transparent, so you can see what's going on inside of it.
The local auto parts store charged $16.28 for one. If you opt for this flasher, make sure its spec indicates it works with a mixture of LED and Incandescent bulbs.
My Victoria has Bratton's main wiring harness with an integral signal system that uses 2 LED tail lights and incandescent bulbs in the cowl lights.
Bob Bidonde
