#1 |
I was lucky enough to find a SW mechanical tach drive and in the process of installing it. There is a fairly thick washer that is used with the original bolt to keep the pulley in place. Does it need to be there with the drive unit ? I have very little clearance as it is in the 32 with a C69A and had to trim the u bolt upper bracket. The diameter of the drive unit is the same as the outside diameter of the washer. Tried to upload a pic with no luck.
#2 | |
![]() Quote:
hb32 .....Send that picture to my e-mail and I will try to post it for you. My e-mail BELOW! DD [email protected] . |
#3 |
Thanks coop
#4 |
#5 |
The spacer/washer I was referring to is visible between the pulley and the tach drive
#6 |
#7 |
There is no need for a spacer, there's a thick (1/4") flat washer between the gearbox and pulley. I'm out of the 674L tach drives at this time.
#8 |
Somewhat confused. In the pic the spacer or washer depending on what it is called is visible. My question is, do I need it there or can I install the gear drive without it. The gear drive diameter is the same as the spacer. Thanks for the reply.
#9 |
Just unbolt the gearbox and remove the spacer, it's not needed. It's hard to tell by the photo....but is there a pulley in place?
#10 |
