11-02-2021, 03:11 PM | #1 |
6 Volt generator test
How can I test a 6 volt generator that has a Field and a armature post to see if it is working. I am trying to determine if I have a bad generator or relay as I am not getting 7 volts and the amp gauge does not show charging, only discharge when turning on lights. I have google it and it does not explain how to test the generator only. Car is positive ground
Thanks, Rick Last edited by Rick; 11-02-2021 at 03:44 PM. |
11-02-2021, 03:18 PM | #2 |
Re: 6 Volt generator test
With a V/O meter set to DC volts, touch your black lead to ground and the red lead to the output post of the generator with the car running. Should get a voltage output reading OR if not its "really" bad.
11-02-2021, 03:21 PM | #3 |
It is positive ground. Which post is the outpost ? The field or arm
11-02-2021, 04:16 PM | #4 |
Rick, I have posted this information numerous times before. At the voltage regulator remove the field wire from its terminal and connect it over onto the armature terminal (not the battery terminal). Start engine and rev up to about 2000 RPM and ammeter should show a high charge if the generator is working OK. If no charge then the generator is faulty. Please list what car you have when asking questions. Regards, Kevin.
11-02-2021, 05:41 PM | #5 |
Thanks Kevin. This is so simple and good to know.
Regards, Rick |
11-02-2021, 05:58 PM | #6 |
11-02-2021, 06:05 PM | #7 |
Just to be clear, where do you put the VOM leads to make this check?
11-02-2021, 06:19 PM | #8 |
tubman, VOM red test lead to a good ground or base of regulator and black test lead to regulator Battery terminal or Armature terminal if you like. This is for a positive ground car. Should have 7.2 to 7.5 volts. Set VOM to DC volts. Have some revs up as well because generators dont charge at normal engine idle speed. Regards, Kevin.
11-02-2021, 08:20 PM | #9 |
Thanks for the clarification; I'm sure it will help many on here.
11-03-2021, 08:39 AM | #10 | |
IN GOD WE TRUST - SEMPER FIDELIS John |
11-03-2021, 08:54 AM | #11 | |
thanks Koates. Mart. |
