10-19-2021, 02:53 PM | #1 |
1957 Ford Country Sedan Transmission Question
I recently bought a 1957 Country Sedan with the original 292 y block and what I believe was called the cruiseomatic or fordmotaic automatic transmission. My question is do I need to start out in the low gear and then shift it to D? If I start out in D am I hurting anything? Is the car actually starting out in 2nd and then shifts to 3rd? I see some people say this transmission is a 2 speed but others say it's a 3 speed. Which is it?
Also, the car is pretty much stock except the previous owner put 2.79 gears in the rear and 15" wheels on it with front disc brakes. Thanks. |
10-19-2021, 03:11 PM | #2 |
Re: 1957 Ford Country Sedan Transmission Question
If it's the original transmission it's a Fordomatic which does start in 2nd if you have the gear selector in the D position. No need to start out in low unless you just want to, although with 2.79 gears there may be an advantage to doing so. Fordo's are 3 speed trannies but normally start out in second as noted above.
Often wrong but never in doubt. |
10-19-2021, 03:47 PM | #3 |
What Dobie said, I have the exact same car and just sent my tranny out for a rebuild. You are lucky to have the 15" wheels and disk brakes as I still have the drums-for now. Lets see some pics and have you checked out the 57Fordsforever.com site?
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-19-2021, 06:32 PM | #4 |
I have the big drums all the way around on my 57, and my car has good brakes.
1930 Artdeco, will a set of Cragars work on my car with the drum brakes? I mean the back of the wheel the face of the drum? I don't want to do anything that will make the wheels move wider. |
10-20-2021, 01:37 AM | #5 |
To tell you the truth I am not sure. I have not played with back spacing much. I know there is a section dedicated to wheels on the 57fofdsforever forum. But I just watched a video of a 500 with cragars on it.
Mike
10-20-2021, 01:07 PM | #6 |
10-20-2021, 02:49 PM | #7 |
I had a set of Cragar’s, garden variety in stock, they were 15x6 with 3 or 3 1/2 backspace. They fit the bird, drums no problem. I didn’t care for them on that car. But I think most modern wheels ( modern 14-15”, not the 22” hoops) fit drums without a problem. Check the backspace both ends, and fender skirts if necessary. Ford changed the center hole size along the way, so the later wheels are going to index (?) on the lugs, not the center opening.
It’s almost certainly on the 57 ford site above. |
10-20-2021, 05:27 PM | #8 |
I will look, thanks. I don't want to change anything, just new tires and a set of Cragars, with he same width, backspace, etc. I have turbine wheel covers, and don't want to go to the wire wheels.
10-20-2021, 06:35 PM | #9 | ||
Many aftermarket wheels have less backspace/positive offset than stock size '57 FoMoCo steel wheels, so they sit a little farther out from the wheel hubs and the wheels are generally wider as well. If you try to order aftermarket wheels with the width and backspace you want, you may find they're back-ordered forever or 'Unavailable'. I waited just over 10 months for a pre-paid set of these standard offset 15 x 6 Torq Thrust wheels. . Last edited by dmsfrr; 10-21-2021 at 01:13 AM. Reason: add photo |
10-20-2021, 10:29 PM | #10 | |
10-23-2021, 11:54 AM | #11 |
DMSFRR, are you happy you bought them? On your T-bird? Did they change the look of your car a lot more than you expected?
10-23-2021, 12:16 PM | #12 |
photo i think the chrome would dress it up a lot.
10-23-2021, 10:10 PM | #13 | |
They're still in their boxes. I originally bought them for the red '55 and it was parked for most of the last year due to virus restrictions and it needing some misc. work. Finally got it out of the garage for the first time about 2 weeks ago, but haven't bought any tires to put on the wheels yet. photo 1, I'm going for this look even though mine has a white top. Maybe the white will work well visually with the machined lip of the wheels. I might use them occasionally on the yellow '57 too, once it gets painted and put back together. Last edited by dmsfrr; 10-23-2021 at 11:53 PM. |
