#1 |
Problem: Starter motor can barely turn over the engine.
Background: Tried two starters that check out fine. We’ve tried hooking them up straight to both 6 volt (used on car) and 12 volt. Starter motor cranks just fine when connected directly to battery. Battery in the car is new and checks out fine under a load test. Ground connections cleaned. We’ve tried adding a supplemental ground. Tried swapping the starter switch. Removed plugs – oddly that allows the motor to turn over without issue! Would really like to read some suggestions as to what to try now. |
