Old 10-07-2021, 12:47 AM   #1
Rodrelic
Default Starting at the beginning
So figured this may as well be assessed, it turned with crank so I bought it last year. After wrangling cables got the floppy switch to run the starter motor, but freewheel. Pulled the drive apart, gear did not turn and slide up the screw. Also the bolts were not tight in the spring. Fortunately kind of knew where the starter parts pile was, found a bendix that was free as well as the correct inner bolt to anchor spring. Bench run properly, got screws to fasten switch down, oil in plug holes, cranked over good and sounded like valves were sealing. Sure is refreshing to work on old stuff for a change. Next spark, then rig up gas, this may be a runner.
File Type: jpg 034E7707-D8C4-4372-8728-121E504DBEAA.jpg (74.3 KB, 217 views)
File Type: jpg 3F6EE7CE-AEF6-49F7-B45C-57B39B869C12.jpg (63.1 KB, 226 views)
Rodrelic is offline   Reply With Quote
Old 10-07-2021, 01:47 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Starting at the beginning
What was it set up to power? I see it is governed.
Old 10-07-2021, 04:29 AM   #3
mercman from oz
mercman from oz's Avatar
After a bit of playing around and sorting out things, Rodrelic got this Model A running again. Good work.
Old 10-07-2021, 06:03 AM   #4
Chuck Dempsey
Chuck Dempsey's Avatar
Good job!
Chuck Dempsey is offline   Reply With Quote
Old 10-07-2021, 07:07 AM   #5
nkaminar
nkaminar's Avatar
I like the cruise control mechanism. I've seen cars with missing engine but in this case the engine is missing the car.
Old 10-07-2021, 10:41 AM   #6
Rodrelic
Yeah, have a frame, fender, cowl, couple doors, need transmission, have axles & small stuff. If I had more car and no engine would have to fish for one of them….to say nothing of the wad of T stuff …then there are the v8’s…..a vicious cycle.
