#1 |
Does anyone know where seam sealer was applied on a 31 Tudor? I know I'll be sealing the header to the visor and the header panel. Any other spots I don't want any water damage once the cars completed. JP
#2 |
If I knew I’d post!
Watching cause I’d like some authoritative feedback I’ve only been working on open cars for the las 25 years but interested Except for Vics Last edited by Oldbluoval; 10-08-2021 at 08:14 AM. |
#3 |
From my experience working on 3 different 30-31 Tudors, there was NO "seam sealer" applied at factory.
Welting around gas tank, fenders and running boards was it. If your roof material is installed correctly, none will be needed.
no more model As for now........
#4 |
I see the vendors sell a 'visor welt' that goes between the sun visor and the wooden header.. I don't know if that helps you or not.
https://www.snydersantiqueauto.com/p...7757&cat=41654 |
#5 |
That is correct that a seam sealer was not originally used. There was welting between the upper windshield panel and the underside of the visor; as mentioned cowl/ tank welting and that was about it on the body. Anything that you would put on, would be extra assurance but not done at the factory.
#6 |
#7 |
my only advise is.
if you are going to seal stuff on the body. NO NOT use silicone sealer. your painter will hate you. ou |
#8 |
Thanks Guys. I'll be using a 2 parts seam sealer so I'll be good. Thanks for the Idea of sealing the roof joint over the "B" pillar Brent. I had forgotten about the 1/4 welt under the visor.
I'm OK, I know the painter!! JP Last edited by Tinbasher; 10-09-2021 at 02:38 PM. Reason: add responce |
