Old 10-06-2021, 03:47 PM   #1
txmike
Default How Fast?
I searched the forum and could not find anything on this and am probably just over looking it.
When I get in my A to test drive it runs up to 20-25 mph in 2nd gear and 3rd gear only gets up to 35.
Is this a linkage issue or? How do I adjust or ?? for improvement?
Thanks
Mike
txmike is offline   Reply With Quote
Old 10-06-2021, 03:59 PM   #2
alexiskai
alexiskai's Avatar
Default Re: How Fast?
Look at this thread. Was ultimately diagnosed as a bottleneck in the fuel line.
https://www.fordbarn.com/forum/showthread.php?t=301355
Old 10-06-2021, 04:00 PM   #3
Patrick L.
Patrick L.'s Avatar
Apparently something is wrong.
Where are you setting the timing and GAV ?
Does the advance linkage work its full range?
Does the throttle linkage open fully ?
Old 10-06-2021, 04:07 PM   #4
nkaminar
nkaminar's Avatar
Hi Mike in Texas,
35 is too low. Should be able to get to 50 or 55 if stock.
1. Check throttle linkage to make sure that throttle opens up full when you press on the accelerator.
2. Make sure that the timing is correct. Set the timing as instructed in the owner's manual. Copies are available from the suppliers. Advance the spark when driving to the point where the engine runs best and that advancing further will provide no improvement. This point varies with the engine speed and how open the throttle is.
3. Make sure there are no parasitic drags on the car, such as the brakes. Put the car in neutral and try pushing it. You should be able to push it fairly easily on the flat.
4. Make sure there is no restriction in the exhaust system or intake manifold.
5. Take a compression check. You should get at least 50 psi on all cylinders for a stock car.
7. Make sure the carburetor GAV is adjusted correctly. Screw in in or out until the engine runs best.
8. Make sure the tires are pumped up to 35 psi.
What body style do you have? 35 mph is not bad for an AA truck. 4 door sedans are slower than other body styles.
Old 10-08-2021, 01:13 PM   #5
txmike
Thanks all for the advice
I am not home and will work on this next week and advise!
Have a great weekend!
Old 10-08-2021, 01:29 PM   #6
Utopia Texas
Utopia Texas's Avatar
Many years back there were bad distributor body’s sold that would not allow the advance arm on the upper plate to move far enough for proper higher speed timing. I do not remember the specifics but hopefully others will chime in.
Utopia Texas is offline   Reply With Quote
