#1 |
1940 Ford, 6 volt. I had the gen and regulator checked out about 2 weeks ago, ck'd good. Recently after starting there's been a noise while running. Found it was coming from the gen (sounded like the starter running but not engaging). Also I thought I heard an occasional "click"om the starter sol. Simple, right?
Changed the starter so with a new Echlin, now starter will not engage. All the connections are clean and tight. Horn works, but nothing when pushing starter button (replaced about 6 mo ago. I've even run a new wire from the starter push button to the solenoid. While driving with the gen making the humming noise I could watch the volt gauge discharge. ANY help would be greatly appreciated as there's a show I want to go to Saturday. Thank you in advance. Paul in CT |
