Old 09-28-2021, 02:22 PM   #1
[email protected]
Default low oil pressure
I'm a new guy with V-8 Flathead Fords. I have a 1946 Ford 239 cu. in. which I believe is the original engine with 64,000 miles. Upon starting, I have 40 psi oil pressure at idle and approx. 70 psi at road speed measured with a mechanical gauge. I'm running 20w-50 oil and I have installed the .063 restriction in the inlet side of the oil filter. When the oil gets to operating temperature, the pressure drops to 5 psi at road speed and 0 psi at idle. The engine runs great with no smoke and no unusual noise. I plan to eventually drop and clean the pan and install a fresh oil pump. Any thoughts?
william.sykes@att.net is offline   Reply With Quote
