09-27-2021, 10:51 PM | #1 |
Threaded 'VS' welded steering arm balls
I have a pair of 32 spindles with out balls on them, and the holes at the end of the arms are tapered for a threaded ball - much the same as a typical,
but later tie rod end. Does anyone know where I can locate "threaded" ball studs for these? I looked at Brattons and Snyders, but all they list in their catalogs are the welded in studs. Thanks, Steve |
09-27-2021, 10:56 PM | #2 |
Re: Threaded 'VS' welded steering arm balls
Macs
09-28-2021, 10:52 AM | #3 |
I got NOS ones from Fred at Southside Obsolete. http://www.southsideobsolete.com/Sou...e/Welcome.html
He goes by Barnfind08 on the early V8 forum. I read that the taper on some of the new ones are not correct. |
09-28-2021, 02:58 PM | #4 |
Hello Steve,
I was in the same boat until I found a pair of spindles that looked like new, searched-high low and found them at CW Ford, Orange County Ca. (800) 322-1932. I just ordered a pair, dont forget to order the nuts if you dont have any. Have a nice day Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
09-28-2021, 04:35 PM | #5 |
Thanks for all the suggestions, and I'll start calling them tomorrow.
09-28-2021, 04:46 PM | #6 |
Thanks for the help. |
09-28-2021, 07:17 PM | #7 |
The taper problem was fixed long ago I gather. The Macs ones are USA made and the correct iron oxide finish and hopefully hardened.
I've got 32 guts in my RHD two tooth. |
