Old 09-27-2021, 12:26 PM   #1
Randy Lausch
Default Exhaust valves
Some of my exhaust valves are running .012 the book says they should be .015 is .012 close enough or should I have the valve stems ground down. If so what kind of grinder will I need. Some where I think I saw where they used a drill sharpener to grind the stems.
Randy Lausch is offline   Reply With Quote
Old 09-27-2021, 01:16 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Exhaust valves
.012" is a bit tight especially depending on which camshaft you're using. Depending on the cam the spec can range form .015-.022".
Apparently you have original type lifters. You might be able to find a garage with a valve grinder that can trim the ends of the valves.
