Old 09-23-2021, 12:53 PM   #1
jrd-28
Default 1950 Ford F1: replacement keys?
I have a '50 F1. Hot-rodded, so little left of the original mechanicals, but some stock things (I think) are the ignition switch and door locks.
Does anybody know of a source for replacement keys in this style?
jrd-28 is offline   Reply With Quote
Old 09-23-2021, 01:07 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 1950 Ford F1: replacement keys?
Midwest Early Ford carries them.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 09-24-2021, 07:31 AM   #3
jrd-28
Ah! So they do. Thanks!
I'm guessing that a standard key-cutting machine should be able to handle them...
Old 09-25-2021, 05:46 AM   #4
FortyNiner
FortyNiner's Avatar
The key cutter may need some expertise. I recently had keys cut at a swap meet and got a full play-by-play of the struggles caused by the configuration. Cutting machines have stops to prevent the cutting wheel from damaging its own fixtures. Due to the particular nature of my ignition key (minimum retained material) the operator needed to gin up shims for holding the blank. It helped greatly that the car was nearby for testing. Your keys may be easier or similarly challenging. It isn't rocket science though.
Old 09-25-2021, 06:11 AM   #5
mercman from oz
mercman from oz's Avatar
Blank Ford Keys wanted by jrd-28. Midwest Early Ford carries them.
