09-14-2021, 09:26 AM | #1 |
Original color ignition cable
Please, what was the color for the ignition wire between i-coil/distributor center on the 1928- Model A.
Black or red?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
09-14-2021, 10:26 AM | #2 |
Re: Original color ignition cable
The high tension wire was black lacquered cloth covered.
09-14-2021, 10:44 AM | #3 | |
The Red was only used on the Ignition Switch down to the Coil. There are two different sizes on those but I don't remember the exact change-over date but I am thinking latter part of '28. |
09-16-2021, 04:47 AM | #4 |
Guten Tag,
this is helpful, thanks! Then I understand correctly that all cables - ignition and electrical - were black at that time except the ignition lock cable in the steel armor tube?
09-17-2021, 08:31 AM | #5 |
Don't understand your question - the only black wires in the system are from coil to firewall block and lighting switch to tail light.
09-17-2021, 11:22 AM | #6 |
Modern ignition switches can be converted to switch power to the coil on and off or is can be like the pop out and switch the breaker point ground circuit. Neither are original since a lot of folks do away with the pop out switch in the modern era. Armored cables for the modern type pop out look alike switch are available to make it all look original. If a person doesn't pull the dash out, Most folks that don't know model A cars all that well will never know it doesn't have an original pop out switch until they get educated. A lot of folks just use what ever high tension lead is available to them but the old black lacquer covered high tension lead was what Ford used. No boots were used as far as I know. Last edited by rotorwrench; 09-17-2021 at 11:31 AM. |
