Old 08-30-2021, 10:03 AM   #1
philcobill
philcobill's Avatar
Question Surface Rust in Coolant Passages.
There is surface rust in the engine coolant passages in my 29 Special Coupe. The rust in the photo looks worse than it really is. I poked my finger into the holes and was able to almost wipe it off. I did not see any scaling or blocked passages in the block, and I imagine that things are okay below where I can't see.
My question is, is this something that I need to address now or should I wait and treat things after I get the head back on and things buttoned up? What would be the best way to address this?
Also, there are some minor scratches on the block. How should I addressed those?
Bill
File Type: jpg 240899839_3030555343830337_4050205894558008270_n.jpg (40.1 KB, 218 views)
philcobill is offline   Reply With Quote
Old 08-30-2021, 10:58 AM   #2
edzaha
Default Re: Surface Rust in Coolant Passages.
Flush it and forget it, not that bad
edzaha is offline   Reply With Quote
Old 08-30-2021, 11:03 AM   #3
alexiskai
alexiskai's Avatar
Address it after the system is sealed, using a de-rusting product like Thermocure or Rust911. Users of this forum have reported success with both; just follow the directions.
Old 08-30-2021, 05:09 PM   #4
mercman from oz
mercman from oz's Avatar
Old 08-30-2021, 09:43 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Turn it upside down and blow out the junk shown in the picture.
Old 08-31-2021, 01:40 AM   #6
updraught
updraught's Avatar
First off, i'd get a Gano filter or similar to stop the rust chunks blocking the radiator, especially if it is a new one.
updraught is offline   Reply With Quote
Old 08-31-2021, 06:35 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
The rust you see is normal.
Bob Bidonde
Old 08-31-2021, 11:44 AM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I think if you run some flex cable thru the passages you can, you’ll have more than surface rust coming out.
Old 08-31-2021, 09:01 PM   #9
SteveB31
SteveB31's Avatar
Run 50/50 anti freeze and this will not happen on the future
SteveB31 is offline   Reply With Quote
Old 09-02-2021, 09:49 PM   #10
Tom Wesenberg
For sure, and it will also save many blocks from cracking during the winter months.
Old 09-02-2021, 10:04 PM   #11
PC/SR
Not a problem. Run anti freeze or rust inhibitor.
PC/SR is offline   Reply With Quote
