Old 08-29-2021, 03:38 AM   #1
Graham Freeman
Default 1933/34 oilchex gauge.
I have an oil chex gauge that clicks on/off with a 9 volt battery test fine,
but does not work when installed and attached to what is supposed to be a nos sender unit.
The amp gauge works ok.
Has anyone used these successfully with a normal Ford oil 50lb pressure sending unit? are they compatible?
Thanks
Graham
Graham Freeman is offline   Reply With Quote
