#1 |
the old style reverse idler uses a pin that is drilled in from the end to oil it.
the new style idler has a hole through the gear to oil it. i have a good gear but bad idler pin. the new style idler pin is the only one available ( as far as i know). is there a supplier for the old style pin? or is there a way to use the new style pin with the old style gear and have proper oiling? thanks ou tom |
