Old 08-21-2021, 04:54 PM   #1
Kube
Kube's Avatar
Default parts ID pretty please :)
You guys have been a great help to this ol' boy in the past. I'm hoping I've not worn out my welcome.
I have what I am only guessing is some sort of ignition lock???
Also, a bunch of metal boxes that I'm guessing hold the wooden coils?
Yes? No? I know nothing about Model T's?
Thanks gentlemen.
Old 08-21-2021, 05:35 PM   #2
29spcoupe
29spcoupe's Avatar
Default Re: parts ID pretty please :)
ignition switch and coil box
29spcoupe is offline   Reply With Quote
Old 08-21-2021, 05:52 PM   #3
mercman from oz
mercman from oz's Avatar
Mystery Parts? Ignition Switch & Coil Parts.
Last edited by mercman from oz; 08-21-2021 at 11:52 PM. Reason: Description change
Old 08-21-2021, 06:05 PM   #4
Kube
Kube's Avatar
Thanks much! Any value?
Old 08-22-2021, 05:54 AM   #5
jimTN
Too good to dump. Ig switch is for a brass radiator T 16 or earlier, not sure of the exact year and the coil box with what appears to be a good lid is 25 back to the brass T's. Both items are in demand.
jimTN is offline   Reply With Quote
Old 08-22-2021, 06:06 PM   #6
Kube
Kube's Avatar
Thanks much!
Old 08-22-2021, 07:54 PM   #7
15max
The slanted lid started in 1917 and the switch went out with the coming of the starter in 1919.
15max is offline   Reply With Quote
Old 08-22-2021, 09:49 PM   #8
redmodelt
redmodelt's Avatar
Slanted lid started in 1915, and except how the lid was constructed, remained the same shape on cars up to 1925 and TT (ton truck) to 1927. That switch was used from 1915 to sometime in 1916. The 1917 model which started in late 1916 used a pressed steel cover instead of the composite material body and inset switch face. There may have been some overlap in switches between the end of the 1916 brass radiator cars and what we call black radiator cars(1917 models) starting fall of 1916.
Without a front shot of the coil box, can not pinpoint the dates of use, but guessing into 1919.
Old 08-22-2021, 10:08 PM   #9
Alex Mcknz
I am sure that the first photo is an ignition switch. What are your plans for these parts?
Alex Mcknz is offline   Reply With Quote
