Old 08-18-2021, 10:38 PM   #1
jerryt
Default Master cylinder
Anyone have a picture of a 1826 ford master cylinder?
Thanks
Jerry
jerryt is offline   Reply With Quote
Old 08-18-2021, 11:18 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Master cylinder
No because, unless it is a stock T that has been upgraded to disk brakes, Ts didn't have a master cylinder. Your roadster pu has been modified so, yours could be one of many different master cylinders used depending on the brake system.
Old 08-19-2021, 12:28 AM   #3
jerryt
So the truck didn’t have a master cylinder on the firewall?
Thanks
Jerry
Old 08-19-2021, 02:51 AM   #4
McMimmcs
McMimmcs's Avatar
No it did not. He explained it very well!
McMimmcs is offline   Reply With Quote
Old 08-20-2021, 11:12 AM   #5
rotorwrench
rotorwrench's Avatar
Ford had specific part numbers for master cylinders beginning in 1939 when they first started using them. The base number for a Ford master cylinder 2140 but the numeric or alpha numberic prefix will tell what it was designed to fit. The only reference to 1826 I can find is the 11-1826 that fits a VW rabbit.
Your vehicle has so much non stock stuff on it that you will be chasing stuff like this for a long time. The mix with Japanese design (and possibly German) parts is not going to help much. Don't assume that the car has Ford parts on it when it has a Nissan/Datsun powerplant.
Old 08-24-2021, 06:37 PM   #6
Two-Gun Bob
Jerry, do you know what rear axle was used for your home brew T? If so, I would do some checking to see if the rest of the modified chassis parts came from that same vehicle.
Two-Gun Bob is offline   Reply With Quote
