Old 08-11-2021, 12:00 PM   #1
terryb270
Default Wire wheels on a 36
I have a 1936 Humpback, would like to put wire wheels on it. what parts do I need to change in order to make 35 wire wheels fit my 36? Rear Brake assy? Wheel hub? Brake Drum? Will the 36 spindles fit 35 Brake assy parts? Any help would be appreciated.
terryb270 is offline   Reply With Quote
Old 08-11-2021, 12:04 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Wire wheels on a 36
Do you still have the mechanical brakes? If so you need a complete set of '35 drums w/hubs. You can use 40-48 rear drums on the '36 rear but wire wheel supports required. For the front because of the spindle you will have to use the '35 drum.
deuce lover is offline   Reply With Quote
Old 08-11-2021, 12:48 PM   #3
1931 flamingo
1931 flamingo's Avatar
Isn't there something "unique" about 36 spindles and drums, deeper or spindles longer??
Paul in CT
Old 08-11-2021, 01:18 PM   #4
deuce lover
'35 and '36 spindles are the same.In '37 the change was made.
Old 08-11-2021, 01:43 PM   #5
DavidG
DavidG's Avatar
With respect, '35 and '36 spindles are not the same. The '36 spindles are shorter and the spacing between the tie rod attachment point and that for the drag link is wider.
Old 08-11-2021, 02:11 PM   #6
deuce lover
Originally Posted by DavidG View Post
With respect, '35 and '36 spindles are not the same. The '36 spindle are longer and the spacing between the tie rod attachment point and that for the drag link is wider.
Oops ,sorry. So the 35 drum will not adapt to a 36 spindle?
Old 08-11-2021, 03:41 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Sheldon ....Compare the snouts on these '36 & '37 drums! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-11-2021, 03:52 PM   #8
deuce lover
DD,I am aware of that difference. David says that the 36 spindle is longer that the '35. I wonder by how much?
Old 08-11-2021, 05:22 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
OK Sheldon, here's the info that I have. The 1935 SNOUT measures 5-3/4" from back plate surface to END of snout...1/4" LONGER than 1936. The 1935 tie rod & drag link holes are CLOSER together (about 1-5/8" O.C.) than on '36 arm.
1935 Spindle
__________________________________________________ _____
The '36 spindle SNOUT is 5-1/2" from Back Plate surface to tip of snout. 1936 tie rod and drag link holes are WIDER separation than 1935 holes on steering arm.
1936 Spindle
T5 W/TORQUE TUBE
Old 08-11-2021, 05:48 PM   #10
Randy in ca
Randy in ca's Avatar
Here's another picture showing the difference in the snout length among other things:
Randy in ca is offline   Reply With Quote
Old 08-11-2021, 05:58 PM   #11
tubman
tubman's Avatar
It looks close enough that it might work. I'd at least try it, but then again, I'm more of a "Hot-Rodder" than a "Restorer".
Old 08-11-2021, 06:03 PM   #12
DavidG
DavidG's Avatar
Thanks for coming to my rescue; I mis-remembered which was the longer one.
Old 08-11-2021, 07:39 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Look again CAREFULLY! The LENGTH of the "schnozz" is not the whole story about spacing. If you'll pay attention to the surface that the seal rides upon, and that the inner bearing bottoms AGAINST, the one on the left in this picture (1935) appears to be wider by an 1/8th inch or more, spacing the bearing farther out from the backing plate. GOOD picture comparison! DD
T5 W/TORQUE TUBE
Old 08-11-2021, 07:52 PM   #14
Brian
Brian's Avatar
I run 35 drums on 36 spindles, no problem- have run that set up for years
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 08-11-2021, 08:04 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Yeah, but can ya run a '36 drum on a '35 spindle?
I've always had trouble wrapping my head around WHY they did this 1936 oddball drum in the first place. DD
T5 W/TORQUE TUBE
Old 08-11-2021, 08:10 PM   #16
tubman
tubman's Avatar
Probably, but that's not the information the O/P was looking for.
Old 08-11-2021, 08:25 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
The 'given' fact here is that the wire wheels ain't gonna fit on 1936 drums! That implies that '35 or '40-ish drums will need to be swapped on front, as well as on the rear. I BELIEVE the REARS ('35 OR '40-ish) are a bolt-on to the tapered rear axle.
DD
T5 W/TORQUE TUBE
Old 08-11-2021, 11:06 PM   #18
Don Rogers
Don Rogers's Avatar
Here's the front spindle dimension comparison. Oops, I got my B dimension reversed 1935 should be 5 11/16" and 1936 should be 5 7/16" Sorry about that.
Don Rogers is offline   Reply With Quote
Old 08-11-2021, 11:17 PM   #19
JM 35 Sedan
JM 35 Sedan's Avatar
Brian, I thought you, or maybe it was someone else here, had confirmed this fit up would work in the past.
Did you have any issues getting the spindle nut to go on far enough for a cotter pin to insert properly, or did you need to tweak something to make it work?
John
Old 08-11-2021, 11:21 PM   #20
Brian
Brian's Avatar
Reason being because of the rod brake setup; much the same as 35...same as 35 front drums are a one off year
