08-04-2021, 10:17 AM | #1 |
Steering Sector grease or oil for 37 Ford??
What grease or oil do you use or recommend for the steering sector box on my 37 Ford?
Your help is appreciated. What about Champion OO? |
08-04-2021, 10:44 AM | #2 |
Re: Steering Sector grease or oil for 37 Ford??
Normally, they use SAE-90 gear oil but some folks use John Deere Corn Head thixotropic grease due to excessive seal leakage.
08-04-2021, 11:07 AM | #3 |
33-34's here and I use SAE 140 .
Actually use it it trans , rear , u-joint and steering . GL4 |
08-04-2021, 12:11 PM | #4 |
The top of the cap says EP (extreme pressure) which leaves the corn head grease out. I use the same lube as the transmission and rear differential SAE 140W
08-04-2021, 01:29 PM | #5 |
Penn Rite steering box lube............................NO leaks.
Paul in CT There is something similar available at Tractor Supply. |
08-04-2021, 02:26 PM | #6 |
Now truth be told....if or when I rebuild that steering box, and confirm I've corrected the leaking problem, I would use the Penn Rite steering box oil, as others here have recommended.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-06-2021 at 07:45 AM. |
08-04-2021, 08:14 PM | #7 |
dtd
08-04-2021, 09:30 PM | #8 | |
John, If you've had such good luck with the Corn Head grease, why change to the Penn Rite? John
Those who do not move do not die, but are they not already dead? |
08-05-2021, 08:19 PM | #9 |
I haven't used it myself, but there have been some recommendations for Super S 00 grease from Tractor Supply
08-06-2021, 07:38 AM | #10 |
John, as I mentioned, "if" I ever do rebuild this steering box, my main goal would be eliminating the leaking issues. To determine that, I would start out by filling the box with oil. Based on what I've heard and read about the Penn Rite oil, it sounds to me like this would be an excellent choice to start with.
08-06-2021, 08:08 AM | #11 |
the trouble with grease is it doe,s not flow in cold weather. we call it tunneling fix the leak it,s ez & fill it with 90 weight like ford says. you lucky guys that live in a warm place it don,t matter
08-06-2021, 08:24 AM | #12 |
Corn head in my '39 p/u's box.
Making the simple complicated for over 30 years. |
08-09-2021, 04:17 PM | #13 | |
Corn head grease should be fine for everyone except that die-hard in Alaska. I have it in the F-1 box in my 32 sedan and think it's great. The F-1 boxes have the same internals as 37 to 48 passenger cars, so it should work just fine in the OP's 37 too. |
08-09-2021, 04:35 PM | #14 | |
Oh, the joy of listening to a Man of Reason! DD . |
08-09-2021, 04:59 PM | #15 | |
Richard, I'd agree with you on using a hi temp grease in the steering box, but JD Corn Head Grease is not hi temp and flows well for it's intended use. There is a video on JD's website that tells the story on how this works in their farm equipment, and it also works quite well in steering boxes, and the early Ford enclosed type universal joint.
08-13-2021, 06:18 PM | #16 |
08-14-2021, 03:08 PM | #17 |
Are instructions available regarding installation of an F-1 box?
My '36 p'up was close to impossible to parallel park. Two-arm pull per each 'turn' - the truck would rock with each pull. Absolutely unacceptable. Didn't the public object to FoMoCo? (and I once read that Chev GM was worse) Is there info regarding why the box was engineered in such a cheap 'Who Cares?' way? Edsel & Gene Gregorie actually 'passed' this piece of 'scrap-iron'? How would the fairer sex fare parking when shopping? At least provide a FoMoCo logo crowbar w/each car . . . one end on passenger floor, the other through the steering wheel spokes - PULL! PULL! PULL! ****** |
08-14-2021, 03:42 PM | #18 |
Tyre's were narrow and roads were gravel , to set up a steering box can be a real challenge ,
