Old 08-03-2021, 02:07 PM   #1
Rodrelic
Default Whatzit agian
Hate to keep asking but have stuff and don’t find a picture elsewhere.
Aluminum carb with windows in the bowl. Not a name or number on the outside
File Type: jpg 47CF8A77-D6E2-4FDF-A2B0-334A985B7DA4.jpg (32.0 KB, 131 views)
File Type: jpg 06ACF24A-AB1E-427C-9F10-FB311AC6B7DF.jpg (29.7 KB, 119 views)
Rodrelic is offline   Reply With Quote
Old 08-03-2021, 02:53 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Whatzit agian
So much stuff, good and bad, was put out for the Model T Ford. You may never find a good answer but keep trying and you never know. Maybe it was a test carb or prototype for an advanced unit or maybe a dismal failure. I once bought an accessory oiler for a T and wondered why they found a warehouse full. After thinking about it and reading the instructions I believe it was a failure because the oil reservoir was mounted to the exhaust manifold. In use it must have cooked or even ignited the oil!
Old 08-03-2021, 03:47 PM   #3
Rodrelic
That looks like a nice little tank should be good to use somewhere. As for the carb I may look inside sometime, maybe try it on something. Just odd it’s the only no name I ever saw.
Old 08-04-2021, 03:42 PM   #4
Ray in La Mesa
It is an "Air Friction" carb. Google "Air Friction carburetor" & scroll down to antique carburetor/ OEM. Second page shows a 20's ad.
Ray in La Mesa is offline   Reply With Quote
Old 08-04-2021, 06:25 PM   #5
Rodrelic
Wow, that is cutting edge. Thank you for the info, maybe I will try it on my T for fun & 40 mg
Old 08-28-2021, 08:27 PM   #6
RAJO special
Yep, an Air Friction carb. The i.d. tag was located on the air inlet tube. It was a brass tube threaded into the body of the carb. Check the MTFCA forum as well for lots of info.
RAJO special is offline   Reply With Quote
Old 08-29-2021, 07:14 AM   #7
Rodrelic
OK thanks, will look around haven’t seen everything in the hash of parts could be the threaded tube is in there.
Old 08-30-2021, 05:13 PM   #8
mercman from oz
mercman from oz's Avatar
Aluminium carb with windows in the bowl?
