Old 07-25-2021, 08:11 AM   #1
1929 Leatherback
Default Correct frame paint color
Hello everyone, new guy here. I have a 29 leather back that has been in the family since new. It has been in dry storage for the past 70 years and is it great shape. But now it has pasted to me and it is time for me to get it going again, so I am about to embark on getting it back into showroom shape. I am starting small. Right now I am rebuilding the shocks, and arms. I am finding it hard to located the correct black color for these parts. Gloss black, semi gloss or matte. I am hoping that someone here can help me out.
Thanks in advance.
1929 Leatherback is offline   Reply With Quote
Old 07-25-2021, 08:15 AM   #2
31Tudor
31Tudor's Avatar
Default Re: Correct frame paint color
Gloss black, both pieces.
31Tudor is offline   Reply With Quote
Old 07-25-2021, 10:17 AM   #3
1929 Leatherback
Thank you!
Old 07-25-2021, 12:34 PM   #4
Gary Karr
Gary Karr's Avatar
Actually, shocks and arms were originally sprayed in a semi-gloss black lacquer.
Gary Karr is offline   Reply With Quote
Old 07-25-2021, 02:17 PM   #5
wrndln
I agree with Gary - semi-gloss.
Rusty Nelson
Old 07-25-2021, 07:16 PM   #6
1929 Leatherback
Ahh... I can do semi-gloss black lacquer Thanks
Old 07-26-2021, 05:58 AM   #7
nkaminar
nkaminar's Avatar
I would go with an enamel rather than lacquer. It is more durable. No one will know the difference.
Old 07-26-2021, 08:24 AM   #8
jb-ob
ERRR?? Who said enamel was more durable than lacquer ??
On a chassis / engine areas lacquer is better suited as it isn't affected by gasoline, hot antifreeze or leaking engine oil.
Use a quality epoxy primer as a base & you are almost bullet proof.
jb-ob is offline   Reply With Quote
Old 07-26-2021, 04:19 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Cured Lacquer does have a harder shell finish than non-catalyzed synthetic Enamel.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-26-2021, 04:43 PM   #10
nkaminar
nkaminar's Avatar
I see lacquer paint cracking after a few years. An epoxy or catalyzed synthetic Enamel or catalyzed urethane would be my choice, or powder coat.
The hand rubbed lacquer paint jobs that were done in the past resulted in beautiful cars.
Old 07-26-2021, 08:46 PM   #11
chrs1961815
chrs1961815's Avatar
I would not try to reinvent the wheel here and stick with what is used these days: urethane.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-27-2021, 06:07 AM   #12
jb-ob
Yes "lacquer paint will crack after a few years" if you pile on excessive coats without adequate dry time in between.
No different than urethane, you need to know what you are doing.
