Old 07-20-2021, 11:59 AM   #1
Jim Brierley
Default Ignitions
F.S. Ignitions. I've just ordered a complete system from them. They have a great web site but due to technical difficulties, their e-mail has been changed to [email protected]. They are easy to deal with and will tailor their dist. to your desires.
Jim Brierley is offline   Reply With Quote
Old 07-20-2021, 12:18 PM   #2
GeneBob
Default Re: Ignitions
For those who are wondering:
"Tailoring your distributor" may involve limiting the total spark advance built into the distributor. When running high compression with a more aggressive cam etc, you need to be sure you do not run your total advance too far out (like more than 28°-30° total).
GeneBob is offline   Reply With Quote
Old 07-20-2021, 01:10 PM   #3
Kinner
I was on my 3rd condenser so just installed a FSI Zipper with the centrifugal advance. Sean at FSI is great to deal with. We are in hilly country in the Shenandoah Valley. I also have a 5.5 head. We set the total advance at 20 degrees with a later curve. Only have about 40 miles but so far seems good. I also have a temp gauge which I feel will help to see if its running to much retard for the condition. I feel FSI is a top notch company.
Kinner is offline   Reply With Quote
Old 07-20-2021, 04:28 PM   #4
JOHNCL
Thank you, Jim, for the info.
For What It Is Worth: My "C" engine with the Dan Price OHV head should not be run with more than 26 degrees TOTAL advance according to Ora Landis the engine builder. I plan on an FSI Zipper with centrifugal advance and Ora told me he modifies it accordingly.
JOHNCL is offline   Reply With Quote
Old 07-20-2021, 05:49 PM   #5
rfitzpatrick
Sean at FSI will work with you later if your a need. Also sells a system that uses your original manual advance
rfitzpatrick is offline   Reply With Quote
Old 07-21-2021, 10:59 AM   #6
Jim Brierley
You guys are right on with advance figures. My head is a little different than most and 20* total is about right for it. Sean had called me a month or so about tailoring one for my head, like stated above, he is good to deal with.
Old 07-21-2021, 02:33 PM   #7
GeneBob
I don't mean to nit-pick or confuse folks but:
Make sure you keep the terms straight. There is the initial advance that you set your spark to when the distributor is installed in the engine.
Then there is the advance built into the distributor (auto advance) that adds to the initial advance when the RPM's are increased.
Then there is total advance which is the upper limit of the sum of initial advance and the built in distributor advance.
Sometimes people confuse total advance with the distributor's built in advance. Your engine builder or HC head manufacturer will have a suggestion for the best total advance as well as your initial advance setting which will provide you with what you want your built in advance should be limited to (often on the order of 20°).
There, that wasn't confusing, was it?
Old 07-21-2021, 04:44 PM   #8
Bruce of MN
Bruce of MN's Avatar
That distinction is correct, of course, but things are simplified if spark for starting is at TDC.
Bruce of MN is offline   Reply With Quote
