Old 07-20-2021, 08:00 AM   #1
rally 1
Default Engine color
Why was green chosen for engine color on Model A’s?
Just curious.
Thanks
Ken
rally 1 is offline   Reply With Quote
Old 07-20-2021, 08:43 AM   #2
Will N
Will N's Avatar
Default Re: Engine color
I don't know, but I bet it's because Henry got a good deal from the supplier!
Will N is offline   Reply With Quote
Old 07-20-2021, 09:12 AM   #3
31Tudor
31Tudor's Avatar
This may be complete folklore, but I had heard that left over paint was mixed together to not waste paint and the mixture, which made green, was then used for the engines. Since Henry was pretty frugal, this makes sense. Don't know if this is fact however?
31Tudor is offline   Reply With Quote
Old 07-20-2021, 09:50 AM   #4
J Franklin
J Franklin's Avatar
WWI surplus olive and black fender dip gleanings, I can see it.
Old 07-20-2021, 04:12 PM   #5
chrs1961815
chrs1961815's Avatar
Never heard a reason, but I will say there is no evidence of them mixing random paint to create the color or using shipping crates for floorboards!
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-20-2021, 06:30 PM   #6
garyjohn
I think Will N nailed it
garyjohn is offline   Reply With Quote
Old 07-20-2021, 11:38 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Studebaker engines were green because of left over WWII paint, so the same may be true for the Model A and WWI, but the mixed left overs sounds very likely.
Old 07-21-2021, 10:55 AM   #8
Gary Karr
Gary Karr's Avatar
Remember that engines were sprayed in alkyd enamel. Initially, the only other enamel paints used were black until the plants started painting wheels in colors other than black in 1930. Bodies were painted in nitrocellulose lacquer.
Gary Karr is offline   Reply With Quote
Old 07-21-2021, 02:40 PM   #9
J Franklin
J Franklin's Avatar
Back to war surplus green. Ford always looked for a bargain.
Old 07-22-2021, 10:09 AM   #10
katy
katy's Avatar
War surplus 10 years after the war? I hae me doubts.
Old 07-22-2021, 10:12 PM   #11
GeneBob
Well, Petty Blue was the result of mixing two paint cans together, and Henry Ford was a notorious penny pincher so stretching paint seems like a good possibility.
GeneBob is offline   Reply With Quote
Old 07-22-2021, 10:34 PM   #12
J Franklin
J Franklin's Avatar
Oil paint doesn't go bad if stored properly.
Old 07-23-2021, 03:06 PM   #13
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
What supplier?? Ford manufactured their own paint (-which included engines).
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-23-2021, 03:19 PM   #14
BRENT in 10-uh-C
Gary is correct with regard to mixing. You cannot mix lacquers into enamels for coloring.
With regard to engine paint, it takes pigments from two different primary colors to make green. The 1928-31 Model-A was not the first Ford vehicle to have a green engine. Ford also used green on the New Improved Ford.
BRENT in 10-uh-C
