07-15-2021, 08:55 AM | #1 |
Lug nuts
What is the correct torque for lug nuts? I have heard from 45 to 55. Can't find any info in Ford Barn records. I know that Ford didn't have torque specs published during the Model A era. Thanks....
07-15-2021, 09:14 AM | #2 |
Re: Lug nuts
Convention is to torque to 50-60 or to do it by feel, both seem to work equally well. The main thing to watch out for is that, if this is being done on freshly powder-coated wheels, the powder will compress slowly under the nut. So, much like head nuts, one should re-torque and check several times until they stabilize.
07-15-2021, 10:40 AM | #3 |
Re: Lug nuts
64 ft-lbs according to Les Andrews "Model A Ford Mechanics Handbook, Volume 1" page A-2.
Why are they called lug nuts? Answer: Originally the wheels on cars were not removed to fix a flat. The tires were fixed on the car. Then removable rims were introduced. The rims were held on my lugs which were held on by lug nuts. Now we have removable wheels but the nuts are still called lug nuts.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 07-15-2021 at 10:52 AM. |
07-15-2021, 03:03 PM | #4 |
Re: Lug nuts
