Old 07-11-2021, 05:42 PM   #1
Conaway2
Conaway2's Avatar
Default 1929 Sport Coupe Front Spring Clamp
As I disassemble the frame and axles, I found the front spring clamp has two bottom plates below the front spring. I have not seen this before on a Model A and don’t think it’s original. It appears that the front U-bolts may be too long ???
The front passenger side frame horn is damaged and the front cross-member has been replaced, so the spring has been removed at some point in the past.
Many thanks for helpful advice -
Jim
File Type: jpg CBC9AFF6-5C80-4A1E-88FB-9E07D25BB646.jpg (68.1 KB, 45 views)
Conaway2 is offline   Reply With Quote
Old 07-11-2021, 06:39 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: 1929 Sport Coupe Front Spring Clamp
Definetely not original. Your U bolts are too long. Probably for a different model with a leaf spring with more leaves.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-11-2021, 08:03 PM   #3
Conaway2
Conaway2's Avatar
I think you’re right. One side of one of the U-bolts has been poorly cut, so I think the U-bolts may not even be for a Model A.
One bottom plate has a hole in it and the other does not. I’m guessing the one with the hole is the correct one to accommodate the bolt through the center of the leaf spring.
Thanks - Jim
Old 07-11-2021, 08:11 PM   #4
chrs1961815
Yes the hole is for clearing the spring bolt. As I remember they were just a depression not a through and through hole. I have only seen ones as a depression.
Old 07-11-2021, 10:48 PM   #5
Conaway2
Conaway2's Avatar
One of the bottom plates has a hole; the other has a depression. The one with the hole looks like it was made that way - not modified.
