07-05-2021, 07:56 AM | #1 |
Carburetor Reassembly
When reassembling a '31 side-bowl Zenith carb what is the best lubricant to use on the throttle shaft ends?
07-05-2021, 09:08 AM | #2 |
Re: Carburetor Reassembly
None
AL in NY |
07-05-2021, 10:35 AM | #3 |
I don't think a little bit of grease will hurt anything. If you have soldered the shaft to increase its diameter for a better fit, the lead will be soft. I have used Never Seize grease. The grease would also reduce air leakage along the shaft. Ed
07-05-2021, 11:13 AM | #4 |
Powdered graphite.
07-05-2021, 12:08 PM | #5 |
I use e z turn lubricant, available thru aircraft spruce.
What Ed said matches my experience. Should improve your idle. |
07-05-2021, 03:46 PM | #6 |
I use "Renolit VLS" from Fuchs-Oil-Company. It is a very viscous grease that is not soluble in gasoline. A plug of this on the outside of the both shaft ends also prevents any air leakage.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
