Old 06-04-2021, 12:35 PM   #1
52 Ford
Default 52 F1 Clutch/Brake pedal bushings
The bushings for the pedals seem to be worn out. I bought new bushings but I am having trouble removing the rivet that holds the assembly together.
The opposite end of the rivet has some sort of waffle pattern in it. When I try to drive it thru it goes a little bit and stops.
Any suggestions as to what I'm doing wrong?
52 Ford is offline   Reply With Quote
Old 06-04-2021, 01:47 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 52 F1 Clutch/Brake pedal bushings
Maybe try drilling it out?? Heat??
Paul in CT
Old 06-04-2021, 02:02 PM   #3
alanwoodieman
grind off the waffle pattern and then drive out
alanwoodieman is offline   Reply With Quote
Old 06-04-2021, 08:57 PM   #4
JSeery
JSeery's Avatar
They are staked in place, they do not come out easy. Grind it down and go to work on it.
Old 06-05-2021, 12:26 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
In addition to all of the above suggestions, I always use a pneumatic hammer to zip 'em right out. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-05-2021, 08:54 PM   #6
planeman182
What are you using to replace the rivet? I can't find the rivet with Ford part # 60542-S.
planeman182 is offline   Reply With Quote
Old 06-05-2021, 10:08 PM   #7
JSeery
JSeery's Avatar
I would call Michael at 3rd generation.
Old 06-07-2021, 10:50 AM   #8
52 Ford
McMaster sells the rivets.
Old 06-07-2021, 04:36 PM   #9
1948F-1Pickup
1948F-1Pickup's Avatar
Another one of those jobs. I didn't see anything holding the pedal shaft from coming out....... so I put it in the press and sheared the pin/rivet thing when pressing it apart.
Ended up machining another pin/rivet.
1948F-1Pickup is offline   Reply With Quote
