05-31-2021, 03:47 PM | #1 |
Help, Need 1934 Ford Engine To Bottom Of Hood Dimension
My car is all apart and at several locations and I am trying to figure out clearance and need help with the dimension from the top of the block on a Flathead Ford engine where the intake manifold sits to the bottom of the top hood on a 1934 Ford.
05-31-2021, 04:06 PM | #2 |
Re: Help, Need 1934 Ford Engine To Bottom Of Hood Dimension
To the centre hinge, where the lowest parts of the flange are, it's around 18" at the front and around 19" at the back. The radiator support rods are lower. This is off my 33 coupe. Would 34s be the same?
Mart. |
05-31-2021, 04:58 PM | #3 |
Mart, That is exactly the number I need. Thank you!
05-31-2021, 06:16 PM | #4 |
Enough room for a blower! DD |
