#1 |
I did a search and came up empty.
Looking for a source for led tail light bulbs for 40 Ford 6V. Any help appreciated. Paul in CT |
#2 | |
Super Moderator
Car has all new wiring, soldered connections and GREAT grounds. I could see zero difference in a blacked out shop. In my opinion, do not waste your money.
#3 |
I put some real white paper around my bulbs to brighten it up a little more.
#4 |
Conversion to 6 volt LED on my 53' Merc. Hope it helps.
https://www.youtube.com/watch?v=boAThNtv3Qg https://www.youtube.com/watch?v=AwQmapDcgoI https://www.ledlight.com/g18-s25-2_6...-polarity.aspx Last edited by Merc Cruzer; 05-15-2021 at 01:27 PM. |
#5 |
Try painting the inside of light white helped my 47
#6 |
#7 |
I don't know about 6V but I put some complete 12V LED light conversions in the rear of my 40 and there was a significant increase in brightness, much safer.
#8 |
i have found that LED bulbs used with certain stock lenses don't always work. Tried this on my '48 and there was no difference. I finally went with the LED inserts which have their own lens from United Pacific. World of difference.
#9 |
I got mine on eBay from China, found all sorts or them for pretty cheap money.
#10 |
LED bulbs have a light frequency (cycles) that is not compatible with many OEM light lenses. LEDs will not penetrate certain glass/plastic chemistries.
#11 |
LEDs that are part of the red lens are super bright, no doubt about it. I cant comment on bulbs.
#12 |
I have the stock clear parking light lenses on the front of my '48. The LED bulbs work perfect with the clear lens , but didn't work with the stock red tail light lens.
#13 |
So far in my 53' Merc, I now have LED, taillights (brake, turn signal and back up), fog lights and head lights. Each of the applications, are now brightener than the original bulbs and I am happy with them. The car has maintained it's original appearance, which was a primary criteria when I started the LED conversion project.
