Old 05-09-2021, 09:19 AM   #1
Lefthander1930
Lefthander1930's Avatar
Question Gear ratio ??
IS there a easy or simple way to check to find out what the gear ratio is in my model A. ??
Lefthander1930 is offline   Reply With Quote
Old 05-09-2021, 09:32 AM   #2
katy
katy's Avatar
Default Re: Gear ratio ??
Which gear ratio?
Old 05-09-2021, 09:50 AM   #3
Lefthander1930
Rear end
Old 05-09-2021, 09:51 AM   #4
GeneBob
If you have a tachometer installed, (or can use one temporarily) you can drive at a known speed and compare your engine rpm to one of the many tables of RPM vs Speed available.
GeneBob is offline   Reply With Quote
Old 05-09-2021, 09:59 AM   #5
GeneBob
Here is a recent discussion on Fordbarn:
https://www.fordbarn.com/forum/showt...ght=rear+ratio
