Old 05-04-2021, 05:57 PM   #1
russcc
Default Purpose of the spring around the OD of brake drum ?
What is the purpose of a spring that fits tightly around the outside of a brake drum ? Thank you.
russcc is offline   Reply With Quote
Old 05-04-2021, 06:35 PM   #2
Mart
Mart's Avatar
Default Re: Purpose of the spring around the OD of brake drum ?
It's a sound deadener to stop the drum "ringing".
I think.
Or maybe to assist in heat dissipation.
In other words I don't know but am prepared to have a wild guess!
Mart.
Old 05-04-2021, 06:48 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
I think.
Mart.
Mart about has it! The spring is supposed to resist a harmonic of sorts that can develop under some conditions, and which can result in noise and squealing. They say that the spring tended to help resist the squealing. And any of you old enough to have watched drums being turned years ago will probably remember the tech wrapping and stretching that big strap around the drum before machining. I believe it's purpose was similar. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-05-2021, 06:15 AM   #4
miniceptor86
miniceptor86's Avatar
No No it’s to keep the cast iron from cracking under pressure and repeated heat cycles like the blocks. Unfortunately this never caught on with the block as there was a controversy as to wether they should be wrapped longitudinal or transversally and no one ever thought to do both.
Springs were for noise damping.
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 05-05-2021, 07:28 AM   #5
Tim Ayers
This is what I've been told as well. I have some that came on some old drums. They are very stiff and take some effort to put on.
Old 05-05-2021, 09:03 AM   #6
rotorwrench
rotorwrench's Avatar
A person may be surprised to know how much a brake drum expands during a hard braking action.
Old 05-05-2021, 09:14 AM   #7
325w
Drums are the most abused parts on the car. Along with the clutch and flywheel. Then the folks that replace the brake lining without turning the drums. Sorry got on a box for a second.
325w is offline   Reply With Quote
Old 05-05-2021, 09:18 AM   #8
glennpm
glennpm's Avatar
Yup, "brake fade" and drum expansion; and that sinking feeling as the pedal keeps getting closer to the floor ;-(
Old 05-05-2021, 02:40 PM   #9
1931 flamingo
1931 flamingo's Avatar
Weren't they used on the Model A to prevent chattering if the drums had been turned too much??
Paul in CT
Old 05-05-2021, 03:44 PM   #10
Ggmac
And rotors compress and get skinnier. Nope but drums do expand and the large rubber was used to keep harmonics down , noise and vibration while turning . I still use a bungie when turning some steel .
Ggmac is offline   Reply With Quote
Old 05-05-2021, 04:22 PM   #11
miniceptor86
It amazes me that the drums ever stayed together. The area were the lug bolts are seems very thin to me and hardly capable to support the pressure applied and heat generated by the shoes.
Cheers,
Jim&Sandy
McGregor, IA
Old 05-05-2021, 04:29 PM   #12
Jack E/NJ
Jack E/NJ's Avatar
Gotta have them springs when they look this good even though you can't see them most of time. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 05-05-2021, 04:44 PM   #13
Tim Ayers
On an OEM drum, that portion of the drum is stamped steel. That center is welded to the cast iron drum surface.
Old 05-05-2021, 04:44 PM   #14
Tim Ayers
Jack,
Where did you get those nice new springs? Mine are all cruddy and rusty.
Thanks,
Tim
Old 05-05-2021, 07:16 PM   #15
Jack E/NJ
Jack E/NJ's Avatar
>>>Where did you get those nice new springs? Mine are all cruddy and rusty.>>>
Heh-heh. Mine are all cruddy, rusty or missing too. I posted a photo of a nitpicker's drum. 8^) Jack E/NJ
Old 05-05-2021, 11:36 PM   #16
Tinker
Tinker's Avatar
Or don't know about arching your brake pads.
