49 ford clutch chatter
i put in new clutch , pressure plate , throw out bearing , pilot bearing. and had the flywheel surfaced . when you let out the clutch it shakes the whole car terrible... no funny noises and the pedal feel good it has new motor and trans mount and everything is tight and its not lowered ... can anyone tell me what could be wrong before i take out the trans. and if i take out the trans what would i look for? i did a search and found the chutch could be in backwards is this poss? it feel like the clutch is working right. its a 49 ford car 239 ci. 3 speed no overdrive. thanks for any help . thanks, tony
