Old 04-22-2021, 11:31 AM   #1
jdpaxton
Default 46 ford rear drum cutting
Is it possible to cut the drum and hub together rather than removing the drum from the hub. I checked one shop with a brake lathe and he didn`t have anyway to center up the hub. The drums I have use studs pressed in from the back side. Hub has the round plate.
jdpaxton is offline   Reply With Quote
