Old 04-14-2021, 09:29 PM   #1
Lefthander1930
Lefthander1930's Avatar
Default Battery Move
Got tired of the hassle to get to the battery. So I seen on this site or another a remedy...So I went for it. I really like the idea and everything came out good! The hood clears.
I'm going to install a disconnect switch which cable +/- for the disconnect?
Lefthander1930 is offline   Reply With Quote
Old 04-14-2021, 09:35 PM   #2
JoeCB
JoeCB's Avatar
Default Re: Battery Move
I think that that was a pretty common change back in the day... I suspect that my 31 Coupe had that "improvement" at some point in it's life as there is a suspicious area of corrosion pitting it that area of the firewall.
Joe
JoeCB is offline   Reply With Quote
Old 04-14-2021, 09:47 PM   #3
51504bat
51504bat's Avatar
I always use the ground cable for the disconnect. My reasoning is similar to removing the battery cables with no disconnect. You remove the ground first so if your wrench slips while removing the hot cable and touches ground you won't create an arch between the wrench and the ground. I'm sure others will offer different opinions.
Old 04-14-2021, 09:57 PM   #4
daren007
Never had a reason to relocate the battery.
daren007 is offline   Reply With Quote
Old 04-14-2021, 09:59 PM   #5
Synchro909
Synchro909's Avatar
I have a sheet metal box I made specially to go there. It holds a few tools, distributor and water pump. All close and handy and out of the way.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 04-14-2021, 10:02 PM   #6
CWPASADENA
CWPASADENA's Avatar
I agree,
From a safety standpoint, always put the disconnect switch on the ground side.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-14-2021, 10:16 PM   #7
CWPASADENA
CWPASADENA's Avatar
I agree,
Chris W.
Old 04-14-2021, 10:27 PM   #8
McMimmcs
McMimmcs's Avatar
although I acknowledge your right to change, I personally want to keep my A as original as possible!
McMimmcs is offline   Reply With Quote
Old 04-14-2021, 11:07 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
i bought a optima battery,didn't look at it or touch it for 16 years hidden unbder the floor is a good place for it
Old 04-15-2021, 05:20 AM   #10
shew01
shew01's Avatar
That’s an interesting idea. Would you mind posting a picture?
shew01 is offline   Reply With Quote
Old 04-15-2021, 06:33 AM   #11
Synchro909
Synchro909's Avatar
I'll see what I can do. Anything electronic and I are not on speaking terms!
Old 04-15-2021, 06:59 AM   #12
Chris in WNC
Chris in WNC's Avatar
battery needs removal so seldom that it would not be worth it to me to have it very much in the way on the firewall.
previous owner installed a disconnect switch which I like very much.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 04-15-2021, 07:56 AM   #13
Big hammer
Attachment 461202
Attachment 461203
Attachment 461204
There's a lot of weight hanging, in the second picture the flat metal bend IMHO needs another bolt ? I've seen cars before on firewalls, my grandpa traded in an A and as he drove into the building his battery fell down from under the floor
get a bigger hammer tap done
Old 04-15-2021, 08:38 AM   #14
GeneBob
I understand the desire to get to the battery more easily as you need to check the level of the acid now and then. I think I will switch to an Optima or other battery that does not need to be checked instead of moving the battery though. Nice installation though.
I would also like to see the pictures of the tool box on the firewall.
GeneBob is offline   Reply With Quote
Old 04-15-2021, 10:23 AM   #15
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Chris in WNC View Post
Battery needs removal so seldom that it would not be worth it to me to have it very much in the way on the firewall.
I have a split floorboard that allows you to access the battery without removing the whole floor. I like keeping my car original looking as much as possible.
I agree with Chris, moving the battery to the firewall would be "very much in the way" and I am not a fan of the look.
