Old 04-13-2021, 06:05 AM   #1
Stoker280
Default 53 F250 Master Cylinder copper gaskets
Hi folks, I replaced the master cylinder on the truck I am restoring and low and behold I have a leak at the copper gaskets that seal the bolt and distribution block to the master cylinder body. I was wondering if anyone new the exact dimension of those gaskets. There is a front and a rear gasket for the bolt and they are different sizes. I know I was shorted one in my order and I used what I had in my shop which I thought was very close to the size. Anyway I don’t want to mess around anymore and I want to see if I can purchase the exact size that is called for.
Stoker280 is offline   Reply With Quote
Old 04-13-2021, 07:35 AM   #2
Ford Freak
Default Re: 53 F250 Master Cylinder copper gaskets
I had the same problem w/my '52 F1 . I took the copper gaskets/washers to my local parts store and got a couple new ones , plus a couple spares . Make sure the surface on the block is really clean! - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 04-13-2021, 10:23 AM   #3
JSeery
JSeery's Avatar
Some people have better luck after annealing the washers prior to using them.
