Old 04-03-2021, 03:29 PM   #1
darrell
Default type f
is there any other fluid i can use in a 55.
darrell is offline   Reply With Quote
Old 04-03-2021, 04:22 PM   #2
KULTULZ
KULTULZ's Avatar
Question Re: type f
Originally Posted by darrell View Post
... is there any other fluid i can use in a 55.
Make-up or service? What is in there now?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 04-03-2021, 07:07 PM   #3
dmsfrr
dmsfrr's Avatar
Default Re: type f
Mercon / Dexron is the closest formulation to the original Type A.
https://www.fordbarn.com/forum/showthread.php?t=296151
dmsfrr is offline   Reply With Quote
Old 04-03-2021, 07:37 PM   #4
darrell
Default Re: type f
i can get type f by the litre only.the stuff is 7.00 a litre.other stuff i can buy by the gallon a lot cheaper which is way i asked.i guess ill have to go with f.the trans is empty now.
Old 04-04-2021, 02:50 AM   #5
KULTULZ
KULTULZ's Avatar
Question Re: type f
How do you want the car to shift, normally or a more firm shift? The fluid type you choose will make a difference.
Old 04-04-2021, 11:24 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
Default Re: type f
Ford-O-matics of the era were specified to use type "A" fluid which was discontinued, but Mercon/Dexron fluid is the recommended replacement type fluid due to its lubricative properties closely matching. Mercon/Dexron can be used in transmissions with the old brass clutch plates or in rebuilt trans with composite type clutch plates.
Daves55Sedan is offline   Reply With Quote
Old 04-05-2021, 05:01 AM   #7
darrell
Default Re: type f
i wasnt worried about hard or soft shifts just if it would damage the transmission.if others are happy with it ill use it.
