04-01-2021, 06:46 PM | #1 |
Removal of two-piece crank pulley
In order to replace a two-piece crank pulley with a billet steel crank pulley, I want to remove the two-piece crank pulley from my '29 Tudor's crankshaft. The motor is in the car. I can't get the second part, which is the sleeve on the crankshaft not the pulley itself. I have tried heating it a bit with a heat gun and clamping on some Vice Grips, to no avail. I would appreciate suggestions -- other than taking the motor apart. I have squirted lubricant on it, but it doesn't want to budge -- it seems like it should just pull off. This is a newly rebuilt motor, which has never been run.
04-01-2021, 07:22 PM | #2 |
Re: Removal of two-piece crank pulley
Why do you want to remove the set-up it has?
04-01-2021, 07:26 PM | #3 |
04-01-2021, 08:12 PM | #4 |
04-01-2021, 08:27 PM | #5 |
04-01-2021, 09:16 PM | #6 |
04-02-2021, 09:31 AM | #7 |
Paul,
Try welding a collar on the end and using a puller. You may have to make the collar if you cannot find one in your junk drawer that will work.
04-02-2021, 10:57 AM | #8 | |
Along the same line of thinking...you could also carefully glue with JB Weld or similar or spot-weld the pulley and collar together ...that should do the trick to get enough force to remove. Still loosen those front pan bolts tho'. I have that split pulley setup on my engine, and I noticed as soon as I tightened the the pan to the timing cover, that inside collar was very tightly bound even tho' the seal was the centering piece - I was worried it was too tight, but it works fine with no leaks (lots of grease during assembly). The pan/timing cover recesses weren't designed for a modern seal, and the two are difficult, if not impossible, to line up as a perfect circle, so can exert some uneven pressure on the seal which likely makes a tight fit on the collar. pulley1.jpg Last edited by kawagumby; 04-02-2021 at 11:19 AM. |
