Old 03-29-2021, 07:14 PM   #1
Bob Johnson
Bob Johnson's Avatar
Default HELP Multi disc clutch removal
I am trying to remove the clutch from a multi-disc clutch. I have the nut off and the clutch will slide out about 2 inches (past the point where the splines are engaged) and then it stops. Is there something I have to remove to get it to slide off all the way? I tried yanking it off but that did not work. Help.
Bob
Bob Johnson is offline   Reply With Quote
Old 03-29-2021, 08:55 PM   #2
Bob Johnson
Default Re: HELP Multi disc clutch removal
Here are pictures of the clutch seated all the way in and a picture of how far I can slide it out before it just stops.
Old 03-30-2021, 03:19 PM   #3
Bill Cilker
Bill Cilker's Avatar
Bob
No pictures were posted
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 03-30-2021, 03:43 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
I see pictures just fine. Unfortunately I do not have an answer for you.
Old 03-30-2021, 04:43 PM   #5
hudson32700
I don't see any pictures either!
hudson32700 is offline   Reply With Quote
Old 03-30-2021, 05:12 PM   #6
Steve Plucker
I see them...It is not hanging up on the shifting forks is it?
Pluck
Old 03-30-2021, 10:02 PM   #7
Bob Johnson
Default Solved
The problem was a mushroomiing of the shoulder on the spine shaft that holds the back end of the clutch. It was about 0.004" bigger in diameter than the rest of the shaft. At the throw out bearing end of the clutch there is a about a 1/8" ridge in the inside of the clutch sleeve. When the ridge got to the mushroomed section it hung up. It took a lot of wiggling but I finally got the clutch off the shaft. I filed down the mushroomed area and it now slides off and on easily. There is a picture here but some of you may not see it. I do not know why.
Bob
Old 03-31-2021, 12:14 AM   #8
Steve Plucker
Very clear to me...good that you got it Bob.
Pluck
