03-21-2021, 11:55 PM | #1 |
1928 roadster pickup cab assembly pictures
Can someone please post pictures of the inside of a 28 or 29 rpu cab? I have a completely disassembled one that I am trying to assemble. Pictures of any braces, the B pillar with latch striker , and rear cab corners would be much appreciated.
03-25-2021, 09:06 AM | #2 |
Re: 1928 roadster pickup cab assembly pictures
can anybody help?
03-25-2021, 11:23 AM | #3 |
I looked for you the other day and was hoping someone else would help you. Unfortunately I don't have much to help you with. The pictures I do have are from a messtoration that we got in that the rear body panel was oil-canning due to the restorer used a grinder to strip the old paint & rust off and over-thinned the metal. We fabricated and added strengthener ribs to the inside to give the body some rigidity again, and correct other issues. Nonetheless, hopefully what I do have can help somewhat. (We also had one other pickup that I did many years ago but I am guessing that was before the digital age when pictures were given to the customer as developed photographs. )
03-25-2021, 05:34 PM | #4 |
Thanks Brett. It looks like you have a wood strip in the back corners, is that original? I have these stiffeners
03-25-2021, 05:43 PM | #5 |
Yes, wood in the corners is original. We added metal stiffeners and spot welded it to the inside of the rear panel.
03-25-2021, 06:02 PM | #6 |
03-25-2021, 06:04 PM | #7 |
Do these end pieces fit into the corners?
03-25-2021, 11:08 PM | #8 |
uncle buck, I have all the cab photos i took when doing my 29RPU. Lots of assembly details. PM me your email address and I will compress a folder containing all my pics and send them off to you.
03-25-2021, 11:49 PM | #9 |
03-26-2021, 08:41 AM | #10 |
Thank you Russ! PM sent
03-26-2021, 09:14 AM | #11 |
I have been following this thread intently since I have a '29 RPU with no back cab parts or pieces. It only has the front cowl/pillar bolted on, so I have no idea what I need for the back part of the cab.
Rather than start a redundant thread on here, would Russ be willing to send me his pics also? This was something I was going to ask about eventually, but since it was already brought up, it would allow me to get started sooner than later in obtaining the necessary components. Any assistance is very much appreciated since I'm new to the Model A world. Craig |
03-27-2021, 10:18 AM | #12 |
Sorry for the delay. Will get pics out today!
Craig, please PM me your email. |
03-28-2021, 01:43 PM | #13 |
Russ said I can share the pictures. Here are the pictures for anyone else that might need reference.
03-28-2021, 01:46 PM | #14 |
More
03-28-2021, 01:50 PM | #15 |
Last
09-03-2021, 12:27 PM | #16 |
This is actually pretty helpful to me as well. I just picked up a really solid, complete 29 RPU, although there was some rust issues on the lower cab corners. I was missing most of the wood. This will help identify what i am missing & give me a reason to use my band saw again
