Old 03-20-2021, 09:11 PM   #1
Talkwrench
Talkwrench's Avatar
Default Best graphite thickness
Hi guys sent an email to Best but I don't think they'll get back too me quick. Does anyone know the compressed thickness of their graphtite 507 head gaskets? Also any prep for them on install?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-20-2021, 11:27 PM   #2
Brian
Brian's Avatar
Default Re: Best graphite thickness
Rob, I can't answer your question...these things disintegrate upon removing the head[s]....That is why, when I build an engine, i fit the heads with no gaskets in place and rotate engine at least two complete revolutions. If there is no contact, you can be pretty well assured of at least .040" clearance with gaskets torqued down.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-21-2021, 05:54 AM   #3
Mac VP
Mac VP's Avatar
BEST head gaskets compress down to about .050 to.053”. Slightly more with the copper clad type (ie perhaps another 2 or 3 thou).
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-21-2021, 06:17 AM   #4
flathead48
I wrote to them before I used them and they suggested that I spray both sides with copper spray.
flathead48 is offline   Reply With Quote
Old 03-21-2021, 06:49 AM   #5
Talkwrench
Talkwrench's Avatar
That's what I was working on, just good to know how much they compress, as a rough I measured them at .060 new.
Old 03-21-2021, 08:17 AM   #6
Ronnieroadster
Ronnieroadster's Avatar
The engines I build using the Best brand gaskets I allow .050 for the additional clearance dimension. For additional help in sealing I only use a thin film of silicone sealer around all of the water holes placing the material on the decks of the block and the surface of the heads but only around the water holes. Doing it this way I have found no water leaks and very good gasket sealing.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 03-21-2021, 04:56 PM   #7
Hal Beatty
Hal Beatty's Avatar
Right here... https://bestgasket.com/head-gasket-bore-thickness/
Or here... https://bestgasket.com/ford-big-bore/
Hal Beatty is offline   Reply With Quote
Old 03-21-2021, 05:34 PM   #8
Lawrie
Lawrie's Avatar
Ronnie, thats good info', I took a set of copper ones off the other week that had only been on for a few hundred miles,I had sprayed them with c/coat all over, and thought about just around the coolant holes would have been easier.
Lawrie
Lawrie is offline   Reply With Quote
Old 03-21-2021, 07:06 PM   #9
Talkwrench
Talkwrench's Avatar
Originally Posted by Hal Beatty View Post
Thanks Hal, I went on their site first and could not find this..?? They dont list the 507 G..
Anyway Best did get back too me , which I didnt expect over the weekend and this is what came back :
Hello
Thank you for you purchase of our 507G Head Gaskets
The compressed thickness is .053+/-.002”
We recommend a copper coat spray such as K&W or Permatex on both sides of the gasket.
Old 03-22-2021, 02:57 PM   #10
mumpsimus
mumpsimus's Avatar
How many times can the Best copper clad head gaskets be re-used?
mumpsimus is offline   Reply With Quote
Old 03-22-2021, 04:06 PM   #11
Bored&Stroked
Bored&Stroked's Avatar
Depends how the heads came off (if you did any prying around the edges - tends to ruin the gaskets).
Also, once they have been compressed, I do not use them again - as I'm not confident they will seal again. To me, the amount of time/effort it takes to disassemble, clean and reassemble the heads - doesn't make any sense to gamble as to whether or not the head gaskets will seal - so I always use new ones (regardless of type).
The only place I don't is on solid dead-soft copper gaskets (race applications) . . . where sometimes I will anneal them and reuse them.
Old 03-22-2021, 10:12 PM   #12
Ol' Ron
Ol' Ron's Avatar
I've been re using them for years, if there not damaged
Old 03-24-2021, 06:10 AM   #13
Bored&Stroked
Good to know Ron . . . I didn't have that much confidence in trying (too much time involved). But, head gaskets are getting to be quite expensive - not like in the good ole' days!
Old 03-24-2021, 05:20 PM   #14
mumpsimus
mumpsimus's Avatar
Thanks Ron. I've used mine twice and wasn't sure if I should buy a new set next time.
Old 03-24-2021, 06:29 PM   #15
tubman
tubman's Avatar
Good to hear it as well. I've got a bunch hanging on nails in my shop ceiling because I just couldn't bring myself to throw them out.
tubman is online now   Reply With Quote
Old 03-24-2021, 09:29 PM   #16
Ronnieroadster
I always reuse the copper clad type gaskets on the same engine block and heads they came off. Heck I have even reused the older type steel clad gaskets as well same way as above.
The gaskets seal perfectly when I use silver spray paint {3 light coats per side} on the gasket surfaces and a small amount of silicone sealer around the wafer holes on the block deck and the head surface areas.
Ronnieroadster
