Old 03-14-2021, 12:35 AM   #1
Talkwrench
Talkwrench's Avatar
Default Piston balancing
Where's the best area for weight removal for balancing. Any tips would be helpful.
Cheers.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-14-2021, 11:21 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Piston balancing
In the old days, I instead wire-wrapped the rod small-ends to add weight to match the heaviest piston if more than a few grams difference. I just couldn't bring myself to mutilating the pistons. 8^) Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 03-14-2021, 11:46 AM   #3
JWL
It is not easy to remove much weight from aluminum pistons. Sometimes a little can be removed under the heads, sometimes from the pin bosses, sometimes the scallops of the skirts can be enlarged, and usually some material can be machined in the lathe from inside the skirts below the pin bosses. In extreme cases for racing, I have drilled many 1/4" holes in the skirts. I figure the minimum head thickness at .175 for cast pistons and .150 for forgings in unblown, gasoline applications.
JWL is offline   Reply With Quote
Old 03-14-2021, 04:50 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
Cheers.
When I need to remove material on a piston like the one in your picture I take it from the inside diameter of the piston at the bottom. I use my lath to remove the material. Another option you have is removing the weight from the inside of the wrist pin using the lath.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 03-14-2021, 05:08 PM   #5
Ol' Ron
Ol' Ron's Avatar
ot sure what you project is but piston weight isn't very important in a street aplication. However the rods are . The rods and crank are a match set and will remain in balance even in an expensive race engine with a change of weight piston set Many race teams have changed pstons and never re balanced the crank. Back in the pre 60's most rebuild engines were ever balanced. At Danbury we never balanced our engines, because thw=ere were no place the get it done. Bells in nJ had a 6 month back log. so I tried t keep my crank assys together,
Gramps
Old 03-14-2021, 07:01 PM   #6
Talkwrench
Talkwrench's Avatar
Thanks guys good information .
Old 03-14-2021, 07:05 PM   #7
Mart
Mart's Avatar
That circular land just up inside the skirt is where the material has been removed for balancing. Like stated above, it would have been done on a lathe.
(Probably).
Mart.
Old 03-15-2021, 08:54 AM   #8
Desoto291Hemi
I remember seeing a video on the tube of them building the Ford V8 engines .
One scene was how they balanced the pistons .
They had a fixture that locked the piston in place above a cutter .
Then as it cut,,,the chips fell into a catch basin and when the chips weighed out right the machine stopped cutting .
It was really amazing to watch,,,,and really fast as well .
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 03-15-2021, 09:15 AM   #9
itslow
itslow's Avatar
The weight of the piston needs to be included when balancing a crankshaft.
You can't change pistons from XYZ grams to ZYX grams without affecting the balance of the system.
Race teams that are replacing parts between runs have ensured all the components - old and new - are the same weight before reassembling the engine.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 03-15-2021, 10:45 AM   #10
Ol' Ron
Ol' Ron's Avatar
Itslow, I don't disagree with you, however the weight of the piston is factored in differently than rotary weight, as the pistons weight is reciprocating. I keep all my cranks and rods together as rotating weight is more important .However, when turning 8 grand all dy long might be different.
Old 03-15-2021, 11:11 AM   #11
Bored&Stroked
Bored&Stroked's Avatar
First of all, weigh all the pistons on an accurate gram scale to determine how close/far they are apart. Many forged pistons are delivered with a very accurate weight between them - like Ross.
The cast ones (as you show) tend to have a lot more variance. If you don't have a lathe and the weights are close, you can always use a air grinder with an aluminum rotary file - you can fairly accurately remove material around the inside perimeter of the bottom of the piston.
I've seen some cast pistons where a wide drill bit is used to remove slight amounts of material up inside the crown . . using a series of small drill removal areas (drill bit size like .500). Might see a half-dozen drill areas inside the crown - each maybe only a slight dish (like the size of the drill bit when the outer radius reaches the material).
Obviously you don't want to weaken the crown, but a lot of times the heavy cast pistons have quite a bit of material up top.
Good luck!
Old 03-16-2021, 05:01 AM   #12
Frank Miller
Frank Miller's Avatar
Did you weigh the pins and pistons separately? The lightest pins with the heaviest pistons has also worked.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
