Old 03-09-2021, 07:54 AM   #1
Desoto291Hemi
Default Flathead radiator with straight water
I know I am not that bright .
I read a lot of posts here where you should put straight water in the radiator with no antifreeze during a test .
Why ?
I have seen several pics here where the Block had a chunk the size of your fist pushed out ,,or a crack running the length of the pan rail or some other disastrous outcome from freezing .
I can understand doing for a short test,,,,,,but looks like too many are forgetting and leaving the water in without mixing in antifreeze .
What is wrong with putting some antifreeze in while doing a test .
If it is cracked already,,,,,the antifreeze won’t hurt any thing more than is already hurt ?
Just curious !
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 03-09-2021, 08:39 AM   #2
tubman
tubman's Avatar
Default Re: Flathead radiator with straight water
If you do have a leak during a test (initial) run, plain water makes less of a mess to clean up than an antifreeze mix.
Just don't forget to change it when everything proves OK.
Old 03-09-2021, 09:25 AM   #3
Mart
Mart's Avatar
I'm preparing a motor for a test at the moment and was going to use straight water. I changed my mind while filling it and went with antifreeze mix.
Mart.
Old 03-09-2021, 09:30 AM   #4
tubman
tubman's Avatar
Just curious Mart; can you explain why you changed your mind?
Old 03-09-2021, 09:53 AM   #5
19Fordy
19Fordy's Avatar
It may be that there is a dye that folks ad to the "straight water" that makes it easier to see a crack or defect?
Old 03-09-2021, 09:58 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
No special dye, just plain food coloring will do the trick if needed.
And in a color of your choice.
Old 03-09-2021, 11:16 AM   #7
Mart
Mart's Avatar
It can still get cold at night here, and I was thinking the water pumps might benefit from lube qualities. No hard and fast reason, I just wavered between the two and came down on the side of adding the anti-freeze. I always run antifreeze anyway, so I thought I might start off as I intend to go on.
Mart.
