03-01-2021, 05:10 PM | #1 |
1954 Mercury Turn Signal Switch
My driver's side brake light has never worked in the few years I've owned this '54 Mercury. Today I had a chance to trace the fault back to the turn signal switch. With a jumper across the brake switch leads and the turn signal switch unscrewed from the steering column, I am able to get the brake light to go on if I manipulate the switch by moving it around. But the light will not stay on when I return the switch to its place on the steering column. Solder joints and wires at the switch terminals are good, so I suspect I have an intermittent short in the Green-Orange Trace wire in the steering column or a faulty switch. The turn signals work as they should.
Does anyone know of a source for this switch? Or what will interchange with it? Searches of the usual suppliers came up empty. Part number from the 54 Merc book is 1M 14486-A. Or has anyone successfully pulled one of these switches apart and fixed it? Thanks in advance.
Document your car with CollectorCarCompanion |
03-01-2021, 05:14 PM | #2 |
Re: 1954 Mercury Turn Signal Switch
Forgot to mention, this '54 Merc is an original 6V positive ground car.
03-01-2021, 05:18 PM | #3 |
There is one listed on the bay right now. Looks as a newer type replacement. Don't know anything about seller.
03-01-2021, 06:25 PM | #4 |
I did several ebay searches and came up empty. Could only find later 12V switches.
03-02-2021, 08:26 AM | #5 |
03-02-2021, 02:58 PM | #6 |
03-03-2021, 05:54 PM | #7 |
With the harness still in the steering column and all the wires still soldered to the turn signal switch, I gently and slowly took the switch apart today. I cleaned up all the contact points and, after several tries, got the 4 tiny springs and 2 contact pads seated correctly and the switch put back together. Now everything works as it should. Fingers crossed that this fix will last for awhile.
03-03-2021, 06:00 PM | #8 |
Don't build them like that anymore, sounds good.
03-04-2021, 08:40 AM | #9 |
You can use the Ford version to rebuild your Mercury, That what I had to do.
03-05-2021, 09:46 AM | #10 |
Thanks for that info, Tomjc. I'll pick one up just in case my fix doesn't last. John
03-05-2021, 12:49 PM | #11 |
John, I have a complete turn signal assembly including the switch and original wires for an automatic. Let me know if you're interested.
03-09-2021, 08:09 PM | #12 |
Lanny, I just sent you a PM on the turn signal switch.
03-10-2021, 02:48 PM | #13 |
It looks like the switch I replaced in my '54 Ford a couple of years ago, but I'm going off of memory. Would they use a different switch for Ford and Merc? The brake light interfaces with the turn signal function so that the brake light can defer (for lack of a better word) to the turn signal on the side that's being signaled. Dissecting the old switch reveals the function.
The new switch I replaced it with was crap. It was broken right out of the box due to cheap quality. I fixed it because a different new replacement wasn't going to be any better, and the original was worn out. Sounds like you're getting a good functioning original, so that's probably ideal. |
