Old 03-01-2021, 10:40 AM   #1
fortyman
Default Front Bumper Grommets
The front bumper grommets for 1940 Ford Fordor. One side of the grommet is wider. Does the wide side go toward the inside or outside?
fortyman is offline   Reply With Quote
Old 03-01-2021, 12:19 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Front Bumper Grommets
If you are talking about the bracket grommet, as I recall they are installed from the outside with the appropriate side facing out.
Old 03-01-2021, 12:39 PM   #3
19Fordy
19Fordy's Avatar
On a 40 coupe the front has the wide side to the inside.
On the rear the wide side is toward the outside.
I would think the same is for a 4 door as the fenders are the same.
