#1 |
I need the outside length and out side width of 1957 FORD t-bird cast valve covers.
#2 |
#3 |
Thanks
#4 |
You can make you own a bolt 5/16 5 " long grade 5 or 8 course thread with shoulder on top cut to length and use fine die cut your own thread. That's what I'll do.
#5 |
#6 |
#7 |
Same gaskets fit metal and cast. The only difference you may run into is that the gaskets for late steel covers had tabs on them. Just cut off.
